different mesh topology
Old   June 27, 2013, 03:52
Default different mesh topology
Charu
aannjj is on a distinguished road
hi, does anybody know how to stitch two same faces having different mesh topology in fluent?
The geometry is quite long ,hence i had to split the geometry in various parts normal to the flow(I did this in gambit and checked "not connected")
Its an enormous problem in fluent.I am able to form one interface combining two separate interfaces that i had named in gambit.but still there are default interiors being created and when I am trying to run calculations,It creates some "empty surfaces". I have no idea what to do..I am not able to successfully delete the default interiors!!
while trying to run Graphics and Animation and displaying contours for those interior faces.. the error is :
"Note: zone-surface: cannot create surface from sliding interface zone.
Creating empty surface."
I had divided the geometry into 8 volumes and the error is displayed(of course!!) 7 times for each partition instance...
aannjj is offline   Reply With Quote
Old   June 27, 2013, 05:28
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
can you post a picture with details where are your splits, etc...
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 28, 2013, 03:56
Charu
gee!, that is something i am not allowed to do..but thanks for replying..but take a mock example.. think of a cuboid..and split it in half by a plane and the "connected" option is ticked off..
I am attaching 3 pngs.
.It is the same cuboid nevertheless and the fluent analysis will be for the whole cuboid..
In first pic..it is the entire cuboid with inlet to the right and outflow to the left.It has symmetry for the entire face facing down.
In second the first volume's leftmost face 'A' is meshed with a boundary layer and tri-mesh.
In third, the second volume's rightmost face 'B' is meshed with entirely different topology for some reason.
In fluent the surface A and B are to be combined to form an interface.. and fluid passes normal to it...but the problem stated above has listed the multitude errors that i faced..instead of just one division the entire cuboid can be divided into many volumes..
i hope you got the error
This is the warning i get when i read the mesh in fluent
"Warning: Partition method "Metis" is not allowed for
autopartitioning for cases with nonconformal
interfaces before the interfaces are defined
and intersected, use "Principal Axes" instead.
You may use the "Metis" partition method
after the case is read in and the interfaces
are intersected.
auto partitioning mesh by Principal Axes,
distributing mesh
parts........,
faces........,
nodes........,
cells........,
materials,
interface,
domains,
zones,
default-interior
inlet
wall1
sym1
int1
int2
wall2
sym2
outlet
fluid
parallel,
Done.
Old   June 28, 2013, 04:49
-mAx-'s Avatar
Maxime Perelli
Originally Posted by aannjj View Post
"Warning: Partition method "Metis" is not allowed for autopartitioning for cases with nonconformal
are intersected."
Use Principal Axes for partitionning.
But when I see your domain, I assume you can run it easily in serial, and you won't have any partition problem
Old   July 2, 2013, 03:41
Charu
thanks a lot.. it worked..
Old   February 28, 2014, 15:05
Default axes partitioning...?
SIVAKUMAR
shiva102 is on a distinguished road
how to do axes partitioning....plz help me out...
shiva102 is offline   Reply With Quote
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Faces during change of topology in the mesh virginie_e OpenFOAM Running, Solving & CFD 3 August 15, 2009 13:32
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
