[ICEM] Detecting negative vlomume elements in ICEM |
July 6, 2013, 01:31 |
Henry Arrigo
Hi everybody
What Kind of quality type should be checked in ICEM for Unstrct Mesh to find the negative volume elements? I checked Quality, Determinant, Skew and Aspect Ratio in ICEM but nothing were found. However when I import the mesh into CFX I get the negative element error. |
July 8, 2013, 11:21 |
Adrian
Hi Henry,
This has been discussed in topics before. In the quality metrics graph, there's an option to display quality by volume. If you look at the histogram, you'll see that your minimum value will be zero or negative. Highlighting this bar will allow you to see where the negative volume elements; you can work from there. Last edited by adunne304; July 9, 2013 at 04:39. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
