[ANSYS Meshing] cannot create virtual cell the variation
Old   May 17, 2013, 08:25
Question cannot create virtual cell the variation
Pjotr
oewnce932c is on a distinguished road
Hi all! I am imported an IGES(500+ surfaces)) in Design Modeller and made some enclosure around.
I want to putt all my 500+ surfaces in an new topology. i can do it but only in min two new surfaces. i want to pack it in one
Error is following:
"Cannot create virtual cell: the variation of the surface normals is too large with respect to the average surface normal of the selected set or your models graphics tesselation is invalid"
Is it possible to set so setting for creating virtual cells?
thanks for your replies!
yachting_rus cup
world amateur racing tour
WWW.YRC.DK
oewnce932c is offline   Reply With Quote
Old   May 20, 2013, 11:32
Sarang Dalne
sarangdalne is on a distinguished road
Auto generation cells doesn't garuntee that you will get the desired virtual cells. You can try changing the behavior of Virtual Topology to "High" which makes the virtual merge more aggressive.
If you don't get desired result after this, I suggest you select all the faces and then merge them.
Please let me know if you have any question.
Regards,
Sarang
sarangdalne is offline   Reply With Quote
Old   May 21, 2013, 07:33
Pjotr
Hi Sarang, thanks for your reply! I tried to change the behavior to High. But it doesn't help
I just select faces from which i want to creat virtual topology and it says "Cannot create virtual cell: the variation of the surface normals is too large with respect to the average surface normal of the selected set or your models graphics tesselation is invalid"
What do you mean with "merge faces"? how can i do it in Meshing?
yachting_rus cup
WWW.YRC.DK
Old   July 12, 2013, 04:03
Pjotr
solution for me was, selecting not all faces at one time.
I just began with aftship and then go to the forship and it worked for me.
I made selections with "Box Select", need 3 times to select the whole ship step by step.
yachting_rus cup
WWW.YRC.DK
How to determine the direction of cell face vectors on processor patches sebastian_vogl OpenFOAM Programming & Development 1 October 11, 2016 13:17
Create a virtual Surface into a domain in CFX PRE chuck209 Main CFD Forum 0 August 13, 2012 12:10
How to determine the direction of cell face vectors on processor patches sebastian_vogl OpenFOAM Running, Solving & CFD 0 October 27, 2009 08:47
Could you please help me about the VTKFoam liugx212 OpenFOAM Pre-Processing 5 February 13, 2008 11:31
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 13:38
