[ICEM] Body Conformal Mesh
Like Tree1Likes
  • 1 Post By Far
Old   July 12, 2013, 18:31
Default Body Conformal Mesh
Syavash Asgari
syavash is on a distinguished road
Dear mates,
I have tried to generate a mesh around a wing in ICEM. It seems that grid generated around the wing root is body conformal (an ellipse), while I couldn't create such a grid earlier!!
I have attached a picture and as it's obvious, grid boundaries have exceeded the block boundary and have formed an ellipse. The question lies here: How is it possible to have control over grid shape?
Thanks
syavash is offline   Reply With Quote
Old   July 12, 2013, 19:06
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Is the wing of constant cord length and angle of attack? You can control the grid shape by moving vertices and edges. You can also have control by associating edges to corresponding curves. If I'm not wrong, I can see from your picture that you are using the o-grid topology.
Regards,
César
cesarcg is offline   Reply With Quote
Old   July 13, 2013, 06:17
Syavash Asgari
Regards,
César
Dear Cesar,
Thanks for replying,
The wing has a taper ratio but there is no twist across the wing.
I see that it is possible to move vertices to define the shape of block (I have done it already).
As you implied, I am using on O-grid mesh type.
I intended to say that why grid cells are not confined in the rectangular block (colored in black) at the root and are forming an ellipse instead.
Regards.
Old   July 13, 2013, 12:42
Cesar
Dear Syavash,
The grid cells are not confined in that rectangular block because they are following the shape of the airfoil at the root. The same happens along the wingspan. If the grid was not following that shape, I guess that the cells near the edges of the rectangular block would probably be highly distorted, resulting in a low quality of mesh in this region. This grid lines forming an ellipse should become straighter as you move farther from the wing. I hope I made myself enough clear.
Why do you want the cells within this block to match the shape of the black rectangle? Is there any special reason?
Regards.
Old   July 13, 2013, 13:04
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
following thread may be useful to you.
http://www.cfd-online.com/Forums/ans...mesh-wing.html
also search for video tutorial on youtube with key words "ICEM Hexa meshing tutorial - Wing with sharp trailing edge "
blgypeng likes this.
Far is offline   Reply With Quote
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Imported ICEM mesh has additional body in the mesh Procyon CFX 1 January 27, 2011 16:21
conformal vs. non conformal mesh otho Main CFD Forum 2 May 30, 2008 11:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
