Can someone help me
Like Tree1Likes
Old   July 18, 2013, 08:28
Default Can someone help me
Eugen Zec
EugenZ is on a distinguished road
Im new here so im sorry if I did something wrong, and about my question I hope there is some little thing I did wrong and can change it easy.
I'm creating a mesh which ill use in fluentbut at the entrance and exits my mesh goes wild and i dont know how to fix it, can someone pls help me.
Im using ogrid and when i use my mesh is good in all places except entrance/exit.
skewnees is awful and it looks like this
[img=http://imageshack.us/scaled/thumb/28/3y1.png]
[img=http://imageshack.us/scaled/thumb/21/wjjj.png]
mb this should be moved to ANSYS Meshing & Geometry
EugenZ is offline   Reply With Quote
Old   July 18, 2013, 11:19
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
it must a problem of associations, share project via dropbox, i have some free time...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   July 18, 2013, 11:54
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Go to blocking > Association > update association and select first three options and apply
Far is offline   Reply With Quote
Old   July 18, 2013, 13:48
Eugen Zec
Hi Far and ty guys for helping me.
https://www.dropbox.com/s/d8w8lnstn5x0tsh/preogrid.zip
this is what i have...and pictures you see are what i get after using ogrid.
I need agood mesh so i can use it in fluent, i need to learn how to do it.
All i know i've learned online so I'm not very good...tyvm
Old   July 18, 2013, 15:03
Eugen Zec
If this can help someone, this one of my version after using ogrid, this mesh is also bad, around intersection of pipes...pls help with this :/
https://www.dropbox.com/s/qc05lk52uytb7v8/postogrid.zip
Old   July 18, 2013, 15:11
Far
Sijal
can you modify geometry at intersection zone?
Old   July 18, 2013, 15:19
Eugen Zec
I cant, I did all my geometry with CATIA
Old   July 18, 2013, 15:25
Far
Sijal
This is good enough ?
Old   July 18, 2013, 15:29
Eugen Zec
Yeah, this looks great, can you explain me how did you do it. I'm sorry if im too demanding, i really want to learn how to do it
Old   July 18, 2013, 15:32
Far
Sijal
I simply did not associate edges to those intersection curves. And Also moved vertices little bit.
Old   July 18, 2013, 15:35
Eugen Zec
Well, you've helped me alot, hopefully this will be good enough mesh for me do some calculations in fluent.
THANK YOU AGAIN
Old   July 18, 2013, 15:37
diamondx's Avatar
Ghazlani M. Ali
try this ...https://dl.dropboxusercontent.com/u/...6/preogrid.zip
Far likes this.
Regards,
Ali
Old   July 18, 2013, 15:46
Eugen Zec
Diamond, can you explain me how did you do that, yours is also awesome, how?
And thank you very much
Old   July 18, 2013, 16:17
Far
Sijal
Originally Posted by diamondx View Post
Much better
Old   July 18, 2013, 16:26
diamondx's Avatar
Ghazlani M. Ali
there is nothing better than a video to explain this. but i can't install a mkv codec due to privileges. i will try to do that from home. meanwhile i did the necessary split. and merge some vertex together, and o-grid were the last... look at the tutorial "3d pipe junction" it is same blocking strategy, you can start from that one to understand
Regards,
Ali
Old   July 18, 2013, 16:36
Far
Sijal
Ali why do you think that "3d pipe junction" uses the same approach? I dont see similar blocking approach in that tut!!!!
Old   July 18, 2013, 16:37
diamondx's Avatar
Ghazlani M. Ali
that geometry looks like half of the one we have here, no ? try to mirror it
Regards,
Ali
Old   July 18, 2013, 16:41
Far
Sijal
No. I have more feeling of "pipe blade tutorial"
Hey did you like the idea of 3d laser scanner ?
Old   July 18, 2013, 16:42
diamondx's Avatar
Ghazlani M. Ali
You couldn't be more helpful than that... hehehe
Regards,
Ali
Old   July 18, 2013, 16:50
Far
Sijal
Your idea is awesome. How did you get it?
