[ICEM] Octree tetra is created only in restricted area
Old   July 22, 2013, 07:37
Default Octree tetra is created only in restricted area
Andrew Kang
earth07 is on a distinguished road
Hi, I'm trying to create simpe tetra grid
but ICEM only creates tetra in the restricted area.
I put the result files.
http://www.2shared.com/file/YC6A6Y0T...o_problem.html
Should you have any idea why this is happening, please let me know..
I'll really appreciate it..
earth07 is offline   Reply With Quote
Old   July 22, 2013, 10:19
Default Answer
sadjad.s's Avatar
sadjad
sadjad.s is on a distinguished road
Send a message via Yahoo to sadjad.s
Hi mate,
the problem is within periodic definition.
ICEM, CFX and Fluent expert
sadjad.s is offline   Reply With Quote
Old   July 22, 2013, 11:02
Default Thanks a lot.
Andrew Kang
I also just figured it out
Here's another question,
I have a multiple edge from mesh check.
Then I found out that if I delete one of nodes of multiple edge-having tetra, then multiple edge problem disappears.
Is it ok to just delete the problematic tetra element's node to tackle the multiple edge problem??
If it's not ok, is there a better way to correct these elements?
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
