[ICEM] Remeshing script using ICEM CFD replay
Like Tree1Likes
  • 1 Post By mateusdias89
Old   September 10, 2013, 09:02
Default Remeshing script using ICEM CFD replay
Mateus Dias Ribeiro
mateusdias89 is on a distinguished road
Hello everybody,
I am trying to perform a simulation of the air flow inside the cylinder of a diesel engine. Since the beginning of this year I am learning about Ansys ICEM CFD and Ansys CFX to perform this task. Now I'm feeling comfortably enough to start working with moving mesh and in order to do this, I wanted to start with a simple example to learn all the procedures of remeshing, that are extremely necessary in case of high mesh deformations. For this reason, I tried to perform the tutorial presented on this article(http://www.edr.se/blogg/blogg/ansys_...cfx_re_meshing) to learn it. I did everything described: Created the mesh in ICEM CFD, recording replay scripts in order to use it later in CFX. Exported the mesh to CFX, created all the boundaries, the motion and the mesh quality control expressions, set a new configuration and a remeshing process defining expressions of the displacement of the moving wall.
However, when I try to run the solution, the geometry is replacing to the starting point during remeshing, even though the plot of the displacement is showing constant progress in one direction. So my question is: What I need to write on the ICEM script to tell the moving parts of the mesh to be remeshed in the new position, due to the displacement?
Thanks in advance,
Mateus Dias Ribeiro
mateusdias89 is offline   Reply With Quote
Old   September 11, 2013, 08:06
Mateus Dias Ribeiro
Hi again,
I found what was wrong. I made a mistake in the script recording process in ICEM.
Thanks anyway,
Mateus
saed likes this.
Old   February 15, 2015, 14:18
Default heeeeeelp
saeed Ebrahimkhah
saed is on a distinguished road
Hello Mateus
I have the same problem and I'm confused
What exactly was your solution, please tell me
Thanks for the help
saed is offline   Reply With Quote
[ANSYS Meshing] Generating Hexa-Core with ICEM CFD Interactive dawdybishop ANSYS Meshing & Geometry 1 October 31, 2017 20:50
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 10:28
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 09:14
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
[ICEM] SCRIPT File in ICEM CFD Saima ANSYS Meshing & Geometry 0 July 15, 2010 14:27
