Jason
Rep Power: 13 ![]() |
Is there any good literature on meshing strategies for blunt trailing edge airfoils? I have only recently become involved with CFD and after my first Fluent run I am not convinced that my current trailing edge mesh is doing a good job of resolving the flow conditions correctly. I have attached a picture of my mesh at the TE as made in ICEM. |
Jason
Ah! I get much better results with the O-grid.
Attached is my new mesh and results at the TE. I could be wrong but that recirculation looks good. |
In the wake region you can make more dense mesh. Do these steps
1. Match mesh between two blocks i.e. o grid and the downstream mesh in wake region by match edge mesh 2. Split wake block at one chord length downstream and pack more nodes there. Step 1 should be repeated if you see the large jumps there. Or do the step 1 after step two. Moreover the mesh in two blocks (after split) in wake region should also be smooth. Again use match edge mesh parameters command. |
#5 | |
Jason
Koushik
Rep Power: 0 ![]() |
Hey,
I just started with my project on flow analysis over a blunt trailing edge. The meshing is been done using ICEM CFD and is solved in ANSYS CFX. I have no prior experience with either of them. Kindly suggest/share if you know any tutorials for meshing of blunt trailing edge airfoil and cfx solver for similar kind of problem. Thanks in advance ! |
#8 | |
Jason
Otherwise the ansys tutorials available on the customer portal should have airfoil tutorials for CFX (I use Fluent). Remember to go back to fundamentals always. |
#9 |
Anas Nur Fauzan
Rep Power: 6 ![]() |
Hey, I just started learning ICEM CFD and I wonder if you can kindly explain the way you used the o-grid around the trailing edge?
Best regards |
airfoil, blunt trailing edge, icem, mesh |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[ICEM] mesh trailing edge wedge | josip76 | ANSYS Meshing & Geometry | 6 | September 1, 2013 12:31 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
