[ICEM] 2D Multi Element Airfoil
Old   October 23, 2013, 14:13
Default 2D Multi Element Airfoil
Jason
jasonbot is on a distinguished road
I've been trying to mesh a Multi Element Airfoil in ICEM for two days now. First I tried blocking but that became very very dodgy.
Next I tried the Meshing Tab. I have about 90% of the mesh done but have one problem. The trailing edge is not treated very well. All cells are completely perpendicular to the boundary and this causes trailing edge problems.
Any suggestions?
jasonbot is offline   Reply With Quote
Old   October 23, 2013, 14:33
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
increase no of nodes on trailing edge.
Far is offline   Reply With Quote
Old   October 23, 2013, 14:41
Jason
I've tried that. The problem is the edges don't 'fan out' like they do when using blocks.
Old   October 23, 2013, 15:55
Far
Sijal
are you using patch dependent algorithm? Turn on respect line elements option...
Old   October 23, 2013, 16:10
Jason
I am using patch dependent.
I've tried turning on respect line elements. The option makes no visible differences to the mesh.
Old   October 23, 2013, 16:19
Jason
Is there maybe a problem that the main body of the airfoil and the trailing edge are physically separate curves?
2d airfoil, airfoil, high lift, icem, multi element
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[ICEM] Blocking strategy for a Multi Element Airfoil (ICEM) mix ANSYS Meshing & Geometry 16 January 17, 2016 13:41
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 11:26
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 10:55
Multi Element Airfoil J.Dumas Main CFD Forum 2 May 13, 2000 07:24
