[ANSYS Meshing] Y Plus range enquiry
Old   December 11, 2013, 08:42
Default Y Plus range enquiry
Raef
firavia is on a distinguished road
I am simulating a flow inside a pipe that has 8 blades, I used the cut cell mesh and after the simulation was completed I checked the Y plus value on the blade wall and the Y plus value was in the range of 30 to 60 for 80 % of the cells but 20 % of the cells near the wall were far from the acceptable range, does that mean that my simulation will be inaccurate or would that mean that at 80 % of blade wall the standard wall function will work okay but at 20 % of the cells the solution will be inaccurate ?
I used K -Epsilon method
Standard wall function
Fluid: Water
Mesh type: Cut cell.
I would be very grateful if you answer my inquiry, thanks.
P.S: I have made a similar thread in Fluent forum but I just figured out that I should have put it here.
Regards
firavia is offline   Reply With Quote
fluent, k-epsilon, standard wall function, y plus, y star
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
unexpected range in pressure level CFD-Post stefank CFX 4 February 2, 2011 05:27
Y+ range suitable for a 650000Reflow of an airfoil Johari Gregorio FLUENT 0 January 1, 2007 14:46
[OpenFOAM] Automatic range in paraview animations arno ParaView 1 August 29, 2006 04:00
