[ICEM] ICEM CFD hex mesh with very small y+
Old   December 6, 2013, 16:05
Default ICEM CFD hex mesh with very small y+
Shenren Xu
Shenren_CN is on a distinguished road
I try to generate the all-hex mesh and have had the blocking done properly.
The mesh quality is very good is I set the edge to be uniformly spaced.
However, whenever I try to refine the boundary layer mesh with small y+,
by setting the edge pre-mesh params to a small length on one end and
use geometric growth for the edge, and then COPY THE PARAMETERS
TO ALL PARALLEL EDGES, the resulting mesh always have negative vol
cells.
I suspect it is because that the PARALLEL EDGES all have (slightly) different
length, and thus I don't know what really happens when the PARAMETER
for one edge is copied to the rest.
Has anyone experienced the same issue, and any suggestions on how to
resolve this?
Cheers,
Shenren
Shenren_CN is offline   Reply With Quote
Old   December 6, 2013, 17:10
Kevin Hoopes
khoopes is on a distinguished road
I have had this problem before where it will break for small values of first element distance. I think the problem is that you are trying to make elements that are smaller than the underlying triangulation of the geometry that ICEM defaultly uses to place the elements. You can either adjust this triangulation to make it finer or use the project to b-splines option and the projection limit to not use the triangulation for node placement.
adjust triangulation
Settings -> Models/Units -> Triangulation
make it really low
or (the first one is kind of a quick fix)
Project to Bsplines
Settings -> Meshing Options -> Hexa Meshing
turn it on
You will have to adjust the projection limit as well, from the help:
"The Projection limit is set to a non-zero value in cases where you want to keep the nodes on the edges and avoid projection to the underlying surfaces. This option is typically used for Navier-Stokes grids where the grid spacing is small relative to the geometry tolerance. Allowing nodes within a gap in the geometry to project would skew the elements. With a value P set to slightly larger than the gap, the nodes would instead be interpolated. The value may have to be set by trial and error depending on skewness or negative determinants being reported by pre-mesh quality checks."
khoopes is offline   Reply With Quote
Old   December 6, 2013, 17:31
Shenren Xu
Thanks for the reply, Kevin. I'll give a try and let you know. Indeed, my first element distance to wall is extremely small in order to get y+ around one.
BTW, Did you happen to have encountered the issue of not having all the edges of the same length when "COPY PARAMETERS TO PARALLEL EDGES". I originally thought this has caused my problem.
Cheers,
Shenren
make it really low
Project to Bsplines
turn it on
Old   December 9, 2013, 08:50
Kevin Hoopes
I have never had an issue with different sized parallel edges. That has always worked fine for me.
Old   July 25, 2017, 23:11
Anaekh
anaekh is on a distinguished road
Thanks for this post. It helped me in solving my problem
anaekh is offline   Reply With Quote
Old   July 31, 2017, 15:07
OVS
Oliver V
OVS is on a distinguished road
Amazing post. I've been looking for this answer for months...
Thanks!
OVS is offline   Reply With Quote
boundary layer mesh, icem, y plus
[ANSYS Meshing] Generating Hexa-Core with ICEM CFD Interactive dawdybishop ANSYS Meshing & Geometry 1 October 31, 2017 20:50
[ICEM] Scrambled data in exported Fluent mesh from ICEM CFD bjnieuwboer ANSYS Meshing & Geometry 1 October 18, 2013 06:56
Boddy fitted Hexcore Mesh in ICEM Cfd Mitch CFX 0 December 29, 2008 06:07
----------------2D mesh with ICEM CFD Abir FLUENT 2 September 12, 2008 23:55
prob while exporting icem cfd hexa mesh to fluent mani CFX 4 March 7, 2007 03:41
