Geometry
Old   December 24, 2013, 04:17
Default Geometry
UTTAR PRADESH
Amit Yadav is on a distinguished road
When Importing the ellipses from the catia to ICEM and then lofting , I am getting the correct geometry but when I am re-opening it after saving it as a project a lot of surface cracks appear on the surface. Even each ellipse is imported in two halves and not as one complete ellipse. kindly suggest some solution to this problem?
Amit Yadav is offline   Reply With Quote
catia v5, ellipse, icem 14.0, import geometry
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 13:02
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS kamran_kibria ANSYS Meshing & Geometry 0 September 15, 2011 05:14
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 26, 2011 23:25
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 19:51
[GAMBIT] import terrain geometry cfdworker ANSYS Meshing & Geometry 2 May 24, 2009 21:40
