[ANSYS Meshing] Meshing problem in a constricted geometry
Old   December 18, 2013, 03:39
Default Meshing problem in a constricted geometry
Kamil ÖZDEN
kozden is on a distinguished road
I want to simulate the blood flow in a simple model and I have a constricted geometry (as a whole body).
I applied edge sizing to the outer and inner diameters of the geometry by using number of divisions option and hard behaviour. The number of divisions from the beginning of shorter part to the end of longer part is as follows;
for outer diameter -> 20, 30, 150 and 75.
for inner diameter -> 15 and 75
However, I got such a mesh (just the edges are divided but the parts between edges are unstructured and the element sizes are random).
I want to obtain a structured mesh (aligned in the flow direction) with a transition of element sizes (getting smaller) from small number of divisions to large number of divisions through the body.
I tried sweeping method but ansys mesher says that this body is non-sweepable. How can I succeed to obtain such a mesh?
Regards,
Kamil
kozden is offline   Reply With Quote
[Workbench] Meshing and export mesh from STL geometry alerfreire ANSYS Meshing & Geometry 0 March 26, 2013 09:25
[ICEM] Meshing on a Complicated Geometry tav98f ANSYS Meshing & Geometry 2 August 17, 2011 11:15
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Problem meshing turb. blade tip clearance geometry Balu FLUENT 0 June 7, 2008 21:10
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
