January 22, 2014, 03:50 |
gambit meshing
I am trying to simulate the two phase flow at a turbine nozzle(water-air) and I have done the geometry(in the bmp file below). I have some problems with the meshing of it because of the irregular shape of the nozzle.I want a more dense mesh across the two walls,to capture the boundary layer and I cannot figure out how to do it. I would like a structured mesh,so it is easy to configure it later (make it coarser and finer, and also move a bit the nozzle to the right,to simulate a different operation point of the machine). The 'face' at the left is for the water and the right one for the air. Should I make 2 virtual faces to enable the implementation of the 2 phase mixture? Thanks in advance Attachment 28160 (I had posted this by mistake at the fluent topic,so I moved it here.) |
[ICEM] ICEM sizing function >>> Gambit and Ansys meshing | Far | ANSYS Meshing & Geometry | 0 | March 3, 2013 10:17 |
Gambit meshing error | jx | FLUENT | 11 | May 26, 2009 10:35 |
problem with gambit unsymmetrical meshing | meenakshi | FLUENT | 1 | March 28, 2008 12:46 |
meshing a fan using gambit | tony | FLUENT | 1 | February 15, 2008 00:28 |
Gambit: too long meshing time! | delsolman | FLUENT | 1 | January 29, 2008 19:06 |
