meshing complex 3-D geometry
Old   January 4, 2014, 12:58
Default meshing complex 3-D geometry
mohamed abdul maksoud ismaiel
M-ISMAIEL is on a distinguished road
dears i'm modeling a 3d model as per attached layout
I've to generate a boundary around the surface walls but i'm not able to mesh the vol that i receive errors
M-ISMAIEL is offline   Reply With Quote
Old   January 6, 2014, 00:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
You are trying to mesh your volume with cooper, but the volume isn't suitable for cooper.
If you need cooper mesh, then you need to split this volume.
Display only the volume you want to mesh to see how you could split it
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 6, 2014, 18:41
thank you for interest
no shem is working.
when i meshed the case without bl it was successfully generated
but now i can't.
i tried to use submab.. mab.. pav but no workinng. if it is possible can i send the file to u
Old   January 7, 2014, 01:01
-mAx-'s Avatar
Maxime Perelli
Then you have a problem with boundary layer
yes you can provide me your dbs file
Old   January 11, 2014, 13:37
Default Sending the dbs file
Dear max
please find attached the dbs file
- i've performed wall bl.
If i didn't mesh the edges first, the generated bl spacing will be random from surface to another, accordingly i had to mesh the edges then perform bl. Does edges meshing cause interruption during volume meshing?
I need your advice to mesh the volumes correctly.
- please highlight my mistakes.
The geometry is a segment of an air ring used for blown film cooling.
I've neglected the inlet port volume and just kept the inlet surface to minimize the meshing.
To guarantee similarity around the inlet port, i've divided the inlet circle to 4 quarters and a square.
Thank you for help.
Old   January 13, 2014, 01:07
-mAx-'s Avatar
Maxime Perelli
I cannot extract the dbs file from your zip
Old   January 13, 2014, 23:38
Dear Max
Is it possible to send me your email
To be able to send you the file without compression. The attachment limit in the forum is small
Old   January 15, 2014, 14:46
Hi max
Where r u
Hopefully every thing is fine
I am waiting for your email
Old   January 20, 2014, 01:05
-mAx-'s Avatar
Maxime Perelli
ok I have your dbs file.
On which volume is your problem?
Old   January 20, 2014, 23:54
Hi Max
As you see i have a problem with meshing the bigger one.
Usually i start with the inlet port . I deleted it's volume and kept the inlet port circular surface to minimize the meshing elements number.
Then mesh the big section.
And move forward to the exit.
Now i can't mesh the big one. After performing the bl
If you have any different opinion i'd be thankfull.
Performing adequate bl through walls is mandatory. I wish you can try to do this yourself to discover my mistakes and advice.
Thanks
Old   January 21, 2014, 01:35
-mAx-'s Avatar
Maxime Perelli
the problem may come from the corner (red marked)
create new BL and disable continuity option
Old   January 29, 2014, 15:12
Dear Max
Thank u i did it and meshed the volume.
Thank you for your time.
During meshing one of the sections
I received a message that no 3d boundary layer generated from surface xxxx
But the gambit generated the mesh.
I understand that gambit generated the mesh but not exactly the same as the b l
Is it correct.
Regards
Hopefully we will be friends
[ICEM] Meshing of fluid and solid zone of complex structure through OCTREE Nils_H ANSYS Meshing & Geometry 8 February 21, 2020 16:34
[ANSYS Meshing] Meshing complex geometry cfdhydraulic ANSYS Meshing & Geometry 15 May 4, 2017 10:09
[GAMBIT] Need advice on meshing technique to be used for this geometry ankur_kr ANSYS Meshing & Geometry 12 March 24, 2014 00:31
[Workbench] Meshing and export mesh from STL geometry alerfreire ANSYS Meshing & Geometry 0 March 26, 2013 09:25
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
