ICEM - hexa blocking
Old   January 29, 2014, 07:00
Default ICEM - hexa blocking
Marco
msatrustegui is on a distinguished road
Hi everyone,
I'm trying to learn how to do hexa meshes with ICEM CFD. I've done all the tutorials given by the software but my geometry is much more complicated than the examples.
Is it possible to do an hexa blocking of a difficult geometry? What I mean is, how much time does it take to control ICEM in an advanced way?
I've atached my case (is a PMSM electrical motor). Should i do it in another way? (Tetra mesh or poliedral mesh)
I've tried Ansys Meshing but I don't get the control i expect of the mesh and when I use the cut cell method it gives me too big meshes (80 M. elements). Any recommendations?
msatrustegui is offline   Reply With Quote
Old   January 30, 2014, 04:44
Default My problem
Marco
I've focused the problem in this way:
1. I've do the blocking of the shaft with an O-grid.
2. I've create another block for the lateral housing, but the mesh of the contact surface between the shaft and the lateral housing is not conformal (and I need it conformal because I want to simulate the heat transfer between bodies).
3. My idea is to do the blocking of the different bodies separately and then merge them. But I don't know how to get a conformal contact surface. I know that there is a tool in Edit Mesh>Merge Nodes>Merge Meshes, but it transform the hexa mesh in another type and I want all the model to be hexa.
Any ideas???
Do i have to focus the problem in another way?
Thanks in advance.
Old   January 30, 2014, 09:21
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
is the analysis for cfd ? or structural mechanics ? You should expect large number of element in hexa as well.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 30, 2014, 09:28
Marco
Thanks for your reply.
My analisys is for CFD. What kind of mesh would be better, tetra or hexa?
Old   January 30, 2014, 09:40
Javi
FJSJ is on a distinguished road
Can you share yuor geometry? I just want to see better than the pictures. And try to think about it.
FJSJ is offline   Reply With Quote
Old   January 30, 2014, 11:06
diamondx's Avatar
Ghazlani M. Ali
for sure, it will require time to hexa mesh your geometry !
meanwhile, try a tetra mesh...
more details , pictures or even the geometry itself can help us judge...
Regards,
Ali
Old   January 31, 2014, 04:20
Marco
I tried to attach it but it's too big. Could I send it to you by email or another way?
Thanks for all.
Old   January 31, 2014, 06:14
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
you can use dropbox for file sharing. or zip files and attach here directly.
Far is offline   Reply With Quote
Old   January 31, 2014, 06:19
Marco
Hope this can help with the problem:
https://www.dropbox.com/s/tozslvpxa5...CFD-online.rar
Old   January 31, 2014, 13:04
Far
Sijal
can you please upload parasolid file? as i am using older version (14.5) and unable to open the file you have just sent...
Old   February 3, 2014, 03:28
Marco
Hope this is what you need:
https://www.dropbox.com/s/f1ajskjtzjzqj52/Geometry.rar
[Workbench] Problem with hexa blocking in ICEM on a parametric study Jeremie84 ANSYS Meshing & Geometry 4 May 13, 2017 12:13
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) Touré ANSYS Meshing & Geometry 2 August 5, 2012 17:27
[ICEM] blocking a seal geometry in ICEM HEXA Chilli ANSYS Meshing & Geometry 1 October 21, 2011 02:28
icem hexa - load different blockings for each part of geometry??? Catthan ANSYS Meshing & Geometry 2 May 28, 2010 11:27
ICEM hexa mesh built with v10 deformed in v11 (degenerated edges) cfxicem ANSYS Meshing & Geometry 1 October 14, 2009 15:06
