[ANSYS Meshing] Setting up Periodic BCs - Need Help ! |
February 6, 2014, 05:25 |
Rep Power: 12 |
Hello all,
I had recently posted regarding problems with my geometry, but now I have managed to get the model into the Workbench Mesher. I am now held up with the problem of creating periodic BCs in the mesher itself. I have referred to a few links/threads but none so far have given a well-defined way of creating periodic surfaces, atleast the ones that I referred. I am modeling the passage of fluid between two compressor blades and I need to define two periodic walls (in the circumferential direction) at the inlet region (axial entry). I tried creating the "symmetry" folder in mesher, and also the "match control" feature, but the mesh fails to get updated. I am also getting the error "cannot determine a matching face/edge" for one of the two faces. Could you kindly tell me how a periodic BC is created? I'd be really grateful if you could outline the process a bit in detail, as I'm very much confused right now after reading about rotation axis, periodicity axis, orientation etc. factors that could affect the successful setting up of a periodic BC? Pls take a look at the attached picture. The compressor has it's axis of rotation about the z-axis (in fluent), whereas it was the y-axis in CREO 1.0 (where I created the geometry). Thanks a lot ! |
February 17, 2014, 07:09 |
Rep Power: 12 |
Anybody? I could really do with your help !
February 19, 2014, 00:39 |
Rep Power: 12 |
Any ideas people??
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Periodic BCs for flow through body centered cubic | Luigi_ | STAR-CCM+ | 1 | January 26, 2011 04:48 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Pressure BCs or Periodic BCs for model of frost on vertical surface? | andy.eco | FLUENT | 2 | March 26, 2010 02:02 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
