[ANSYS Meshing] Can someone help me improve my mesh? |
February 16, 2014, 12:24 |
Rep Power: 12 |
I'm quite new to ansys meshing. I don't know if the insert mesh methods need to be prioritised or.... because I only want to know the surface temperature of the blocks and the liquid distribution inside the liquid box. The basic structure can be shown in the pictures below. Above the box (liquid zone with inlet and outlet), there are four blocks, inner blocks and outer blocks have different solid materials. Four cylindrical pipes are inserted into those blocks as heaters. In between the block gap, there is a plate and a bended heat pipe. Can someone help me improve the mesh quality? Thank you! |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 09:36 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
