[Workbench] High Cambered Aerofoil Meshing Problem (Workbench) |
February 16, 2014, 05:39 |
Eleanor Rajaratnam
Rep Power: 12 |
Hi! I've been following this tutorial:
https://confluence.cornell.edu/displ...Airfoil+-+Mesh for creating my mesh around this specific aerofoil, however due to it's high camber and asymmetry instead of using the Mapped Face meshing technique I applied the Multizone Meshing one where the following are my constraints: Mapped mesh type: Hexa Free mesh type: Not Allowed However the following image shows the discrepancies from just below the bottom edge of the aerofoil to the centre line x-axis. How can I resolve this and any another of the errors that have appeared (such as overlapping geometry)? Dropbox of files: https://db.tt/VIRzWkbe Any help is truly appreciated! Kind regards, Ele |
February 16, 2014, 06:14 |
Alex
Rep Power: 47 |
Here is a thread about the same topic.
http://www.cfd-online.com/Forums/flu...ease-help.html This might have been hard to find because of the "vague" title. |
February 16, 2014, 06:59 |
Eleanor Rajaratnam
Rep Power: 12 |
Hi, for the geometry setup I used this particular tutorial: http://www.mne.psu.edu/cimbala/Learn...ial_Airfoil.pd
Which I believe follows the 'Form new part' as you suggested in that thread? When you suggested to 'merge' the two sections how would I go about that? Thank you for your reply!! |
February 16, 2014, 07:10 |
#4 | |
Alex
Rep Power: 47 |
February 16, 2014, 07:20 |
Eleanor Rajaratnam
Rep Power: 12 |
I'm really new to this so please could you explain in a little more detail?
The only boolean command I used during Design Modeler was to remove the airfoil from the fluid volume. Thanks once again. |
February 16, 2014, 07:41 |
Alex
Rep Power: 47 |
Then you already know how to do it.
Only this time, you have to unite the face that is causing the distorted mesh with the adjacent face. There is even a picture in the linked thread. Please note that in the cited thread a completely different approach was chosen in the end. |
February 16, 2014, 08:04 |
Eleanor Rajaratnam
Rep Power: 12 |
I have united them using a boolean however when I ten try to open it for meshing I am only left with the bottom left quadrant and the aerofoil! (The other 3 quadrants have disappeared even though they still appear in design modeler)
February 16, 2014, 08:20 |
Alex
Rep Power: 47 |
Post a screenshot of the model tree in Design Modeler before you proceed to the meshing application.
February 16, 2014, 08:44 |
#9 |
Eleanor Rajaratnam
Rep Power: 12 |
Thank you.
February 16, 2014, 09:03 |
#10 |
Alex
Rep Power: 47 |
My bad.
I forgot to mention that we need screenshots where we actually see the relevant parts of the model tree. Expand the geometry section and post at least 2 screens where you clicked on each of the 2 "parts" so we can see its details in the details view. |
February 16, 2014, 09:23 |
#11 |
Eleanor Rajaratnam
Rep Power: 12 |
Ah sorry about that, is this good enough? I deleted the boolean to show you the two specific parts.
February 16, 2014, 10:04 |
#12 |
Alex
Rep Power: 47 |
I dont feel like we are going to solve the problem this way. For example, I have no idea where the line body is coming from.
I recommend you start over again and use the approach outlined in the linked thread ("bottum up", separate sketch for each of the four planes). |
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
ANSYS 13 X64 Workbench problem: "Could not connect to local server" | ggc | ANSYS | 38 | October 7, 2018 17:11 |
[DesignModeler] Meshing Aerofoil Workbench (Design Modeller) | elebelly | ANSYS Meshing & Geometry | 2 | February 15, 2014 14:56 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
