[GAMBIT] GAMBIT edge problem
Old   February 24, 2014, 16:39
Question GAMBIT edge problem
SJD
Sajjad
SJD is on a distinguished road
Hi all
I am new to GAMBIT and FLUENT
I created vertices by using this journal code:
$i = 0
$imax = 5
$inc = 0.0001
do para "$i" init 0 cond ($i .le. $imax) incr $inc
vertex create coordinate $i (SQRT($i)) 0
enddo
this code creates vertices of the y=sqrt(x) function (create 15974 vertices!!!)
So, now I want to create an edge by fitting a smooth curve between all of these vertices( the most appropriate edge form these vertices).
What is the most appropriate edge type for the best accuracy??
I tried to create edge with NURBS edge, first I selected all vertices and then I clicked on Apply, but when I zoom on the edge it seems that edge didn't pass between all vertices (the edge has a little distance from the vertices except the first one and the last)!!!!
Why??
NURBS edge is useful for this case, isn't it??
what is my fault?
SJD is offline   Reply With Quote
Old   February 25, 2014, 01:28
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I never used this funtionnality, but the help is mentioning 2 options: interpolate & approximate
Did you try both options?
https://www.sharcnet.ca/Software/Gam...e_create_nurbs
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 25, 2014, 03:31
SJD
Sajjad
Thanks a million for your answer dear Maxime,I've written the journal code by using from your last answer (fluent & gambit journal)
yes I tried the both method (interpolate & approximate) but the result was same!
but according to the help file interpolate should work!!!
Old   February 26, 2014, 00:45
-mAx-'s Avatar
Maxime Perelli
Mesh your edge. And re-check
Old   February 26, 2014, 15:56
Smile
SJD
Sajjad
You were right!
when I meshed the edge, the mesh boundary exactly passed from the vertices!
Thanks
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Gambit error- the edge degenerates into a point Jai FLUENT 1 September 23, 2006 04:00
Gambit face meshing with a common edge stella FLUENT 1 October 28, 2005 05:09
Problem when I run old gambit jou file with new xfshi FLUENT 0 March 31, 2005 13:03
