[ICEM] wind turine blade periodic
Old   March 6, 2014, 18:21
Default wind turine blade periodic
Papis
papis is on a distinguished road
Hello all,
I am trying to mesh a wind turbine blade using 120 degrees periodic conditions.The input that I have is the iges file which contains the whole blade geometry.I build all the required geometry using ICEM.
Because I have the whole blade i need to cut it at the periodic boundaries to match the periodic faces.
The problem is that when mesh generating(first cell at 1e-06) , volume orientation problems are created exactly at the root region(where the periodic meets the blade) where the blade geometry is almost a cylinder(I say that to imply that the blade geometry there is smooth).
Do I have to use a CAD preprocessor to create the cuts and the whole model and then use ICEM for meshing only or does ICEM can handle this kind of things?
I asking a kind of generic question because I am not sure whethere there is something wrong with the meshing params(blocking,bunching etc) or is a surface problem in generation of geometry.
I have the basic geometry in pictures attached for better understanding of my issue.
Any information would be really helpful.
papis is offline   Reply With Quote
Old   March 10, 2014, 05:33
Sebastian Engel
bluebase will become famous soon enough
in ICEM, there is a feature to create curves by intersecting surfaces. With this curve you could trim surfaces of the blades base.
I can't check right now, there are two ways to trim these surfaces. creating curves with a curve feature or using a feature of the surface page.
bluebase is offline   Reply With Quote
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 04:09
Wind Turbine Blade rotation mmd_knr FLUENT 1 August 8, 2012 14:52
simulating wind shear profile for a wind turbine--> How??? mohammad FLUENT 0 April 14, 2012 23:54
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
Mathematical analysis of the cyclic stresses in the Wind Turine Blade Root milindashokshende Main CFD Forum 1 May 26, 2010 10:36
