[ICEM] Blocking in ICEM
Old   March 11, 2014, 12:28
Default Blocking in ICEM
Minoo
MAP7 is on a distinguished road
Hi!
I'm a beginner in CFD, and am using ICEM for hexa meshing. I've attached my geometry in 2D and 3D. I have problem with blocking my 3D, since there are so many curves and I find it difficult to associate edges to all these curves. I wonder if I can block the 2D model instead and then revolve the block and continue with meshing. Does that make any sense?
I appreciate any sort of help.
Thanks in advance,
MA
MAP7 is offline   Reply With Quote
Old   March 11, 2014, 17:48
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
This is the normal way of doing it, go for it ...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 12, 2014, 13:32
Minoo
Thanks!
Old   March 12, 2014, 21:34
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
Is the revolve feature similar to extruding blocks along one of the coordinate directions and then setting pre-mesh parameters along the extruded length?
Is it possible to create a 3D part from an initially 2D sketch by using revolution in ICEM CFD?
Looking forward to your responses.
Mechanical Engineering
Sydney, Australia
Crank-Shaft is offline   Reply With Quote
Old   March 12, 2014, 21:50
diamondx's Avatar
Ghazlani M. Ali
Yes , in create a block you have the option "2d -> 3D", there you can extrude along a direction or revole; you will then get your 2d blocking
Regards,
Ali
[Workbench] Problem with hexa blocking in ICEM on a parametric study Jeremie84 ANSYS Meshing & Geometry 4 May 13, 2017 12:13
[ICEM] ICEM Beginner Help - Blocking 3D Vane Vortex Generator Crank-Shaft ANSYS Meshing & Geometry 10 March 23, 2013 21:24
[ICEM] Structured grid without blocking in ICEM BahaZero ANSYS Meshing & Geometry 19 March 5, 2013 11:36
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) Touré ANSYS Meshing & Geometry 2 August 5, 2012 17:27
[ICEM] Using Blocking with ICEM (infinity lines appear) Touré ANSYS Meshing & Geometry 6 August 5, 2012 17:07
