[ICEM] Blocking stategy at a volume transition
Old   April 17, 2014, 02:39
Default Blocking stategy at a volume transition
Studi is on a distinguished road
Hi!
I'm stuck at blocking a volume transition of an extrusion die, which I treat in a project of mine. As you can see in the first picture appended, the mesh doesn't fit the geometry. I think it's a problem of the associations, but I can't get it working properly. Furthermore I am not sure about the necessary blocking itself in this region. Since nobody could help me with my problem I figured, maybe someone here has the time to take a look. I've uploaded a Zip with the files externally. https://drive.google.com/file/d/0Bxd...it?usp=sharing
Thank you!
Sebastian
Studi is offline   Reply With Quote
Old   April 17, 2014, 07:20
Javi
FJSJ is on a distinguished road
Did you try to associate face to surface in that region? Maybe you need to make a split (I mean in your last picture).
FJSJ is offline   Reply With Quote
Old   April 17, 2014, 07:31
Thanks FJSJ,
I will go with that and try it again... I assume with by splitting you mean the upper block in the last picture?
Sebastian
Old   April 22, 2014, 07:14
I've solved the problem myself. Basically I had to split the blocks more to connect the edges correctly.
Thread can be closed. Thanks!
Old   April 22, 2014, 09:07
Javi
Ok. Happy for you. The split I mean was in bottom block in your third picture.
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
Mesh transition (volume) in a cylinder PBruschi ANSYS 0 August 27, 2012 09:28
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[ICEM] how to realize smooth transition of volume mesh? yangboMAE ANSYS Meshing & Geometry 6 December 15, 2009 19:24
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
