Easiest way of Generation of Conjugate Meshes for CHT Conjugate Heat Transfer
Old   April 25, 2014, 10:52
Default Easiest way of Generation of Conjugate Meshes for CHT Conjugate Heat Transfer
AGNIMITRA
mitra22 is on a distinguished road
Hi ! Everyone
I have the complete CAD model of an axial turbine stage. By complete CAD model I refer to the solid of revolution with all the casing,hub attributes, followed by a rotor disk.
Bluntly put, my objective is to carry out Conjugate Heat Transfer analysis considering the end walls of the casing and the disc.
Now!
Is it a good idea if I sit down on ICEM-CFD and try carving out the fluid and solid domains along the curved planes out of the CAD model, then go for meshing.
(Or)
I also have the meshes for single passage fluid domains, the solid blades.Is it better if I move on from there? but I think we will face problems in matching the meshes.
Please advise me on this.
mitra22 is offline   Reply With Quote
Conjugate heat transfer in a counter flow heat exchanger abhijithmohan FLUENT 2 March 23, 2014 08:10
heat flux on solid surface in conjugate heat transfer skuznet OpenFOAM Pre-Processing 0 December 10, 2013 00:36
Conjugate heat transfer in reacting flow ali_1364reza OpenFOAM 1 May 30, 2012 14:15
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 17:31
