[GAMBIT] change 3d to 2d
Old   July 9, 2013, 11:19
Default change 3d to 2d
FHydro
flow_CH is on a distinguished road
Hello.
I have a 3d model in gambit. I want to use part of that model for using in 2d of fluent. I am erasing other edges and faces but in exporting the mesh gambit give me this error: please see image
I checked "export 2d x-y mesh" but it does not work.
I think since i have z coordinates, it produce the error
How can i change 3d to 2d?
Thanks
flow_CH is offline   Reply With Quote
Old   July 10, 2013, 01:10
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
are all your vertices in (Z=0) plane?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 10, 2013, 01:27
FHydro
No. I said "I think since i have z coordinates, it produce the error". How can i fix that z coordinates to 0 ?
Old   July 10, 2013, 01:41
-mAx-'s Avatar
Maxime Perelli
Move your surface for having all your vertices with Z=0 (enable Connected Geometry option)
Old   July 10, 2013, 08:37
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by flow_CH View Post
Hello.
Thanks
For 2d analysis you must consider:
1. does 2d analysis represents your 3d case? For example 2d case may give you good result for the 3d circular duct but it is not the case for transition duct changing its shape from circular to rectangular shape.
2. Your geometry must be on X-Y plane.
3.For axisymmetric case , model axis must be X-axis.
Far is offline   Reply With Quote
Old   May 2, 2014, 06:09
Sheng
shizijianmo is on a distinguished road
I have the same problem.
All my drawings are on x-z plane, so it's surely a 2D drawing. Is there any way I can change all the drawings directly to x-y plane? Thanks!
shizijianmo is offline   Reply With Quote
Old   May 2, 2014, 07:22
-mAx-'s Avatar
Maxime Perelli
with copy/move tool, you can rotate all your entities
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 06:37
Old OpenFOAM Users, Read This if you Want to Change Username pete Site Help, Feedback & Discussions 0 March 16, 2009 04:29
Model foaming process: change the volume / density pmp77 CFX 0 November 18, 2008 09:53
How to change contour line thickness? Mishar Siemens 0 December 15, 2004 10:28
How to change the reference pressure value to 0 Pa Lee Siemens 2 July 1, 2003 00:32
