[ICEM] An Interesting Blocking Issue
Old   May 17, 2014, 16:28
Default An Interesting Blocking Issue
Andy
Ajmooch is on a distinguished road
I'm relatively new to ICEM and am in need of some help. I'm attempting to block out a moderately complex part so that I can produce a replay script and run a parametric study on a range of geometries. The part is cyclically symmetric, so cut into thirds it looks like this:
I've been having decent success thus far getting the blocks/premesh to associate to the complex geometry/fillets:
I've been using block splits and a spline edge split on the upper edges to sculpt all this out. The issue I keep running into is that when I try to add nodes radially (so that I don't have these massive pizza-slice elements) everything explodes:
3 nodes
10 nodes
Here's a couple pics of my current blocking:
I've been trying a variety of approaches--I tried edge-splitting the edges that should be associated with the inner and outer radii to make them match up, which just caused more trouble. Associating the edges that I think should connect to the outer radius causes similar issues.
Any tips on how I can block this out? Am I approaching this in the wrong way entirely, or am I just missing something vital?
By the way, a lot of my strategy here is coming from Simon's elbow tutorial and this one, (which I think is by Far? http://www.youtube.com/watch?v=roZNUbhFVJ0)
Feel free to let me know if any more info is needed to tackle this problem.
Thanks,
Andy
Ajmooch is offline   Reply With Quote
Old   May 23, 2014, 09:46
Sebastian Engel
bluebase will become famous soon enough
Are you sure about the associations of the edges marked in the following picture?
It seems to me, those edges needs to be associated to the outer radius's edges or surfaces. The arrows seem to indicate, that right now, those edges are projected to the inner radius.
bluebase is offline   Reply With Quote
Old   May 23, 2014, 12:26
Andy
I've addressed that, actually; associating those edges to the outer surface pretty much immediately results in the pre-mesh skewing beyond recognition. I've managed to solve the issue, though--I just created another part out of that negative space that I was trying to fill, and called that the fluid. Meshed up beautifully.
Currently just trying to get FLUENT to export XY data in something other than SI units, which is apparently impossible -.-
Old   May 24, 2014, 12:20
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Can you share this geometry on dropbox, I'm tempted to try this !
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
associations, blocking, icem, meshing
[ICEM] Problem to load the blocking biasilveira ANSYS Meshing & Geometry 2 February 24, 2013 22:04
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) Touré ANSYS Meshing & Geometry 2 August 5, 2012 17:27
[ICEM] Blocking strategy BrolY ANSYS Meshing & Geometry 0 July 22, 2010 04:46
VOF- Interesting issue Dave FLUENT 0 December 18, 2000 17:49
