May 28, 2014, 05:29 |
Bad Mesh at Volute-edges
Daniel Frederik
Rep Power: 12 |
I'm meshing a volute, the mesh doesn't respect very well the edges. In the pictures it shows how the elements don't follow the edge at the Inlet. What can I do here? Thank you in advance |
May 28, 2014, 09:59 |
Daniel Frederik
Rep Power: 12 |
I just found the answer to the problem. Decresing the Topology Tolerance helped.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
How to improve bad Volume Mesh in Edges | renee | STAR-CCM+ | 4 | January 3, 2014 08:29 |
[ICEM] Checking the mesh -> problem of single edges | Clecl | ANSYS Meshing & Geometry | 21 | September 24, 2012 04:04 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
