May 16, 2014, 10:38 |
how to improve hexa mesh quality?
Rep Power: 12 |
hi everyone,
Right now i doing my final year project, i doing the scavenging simulation process and for my model, i use ICEM for meshing. I still new in ICEM, i hope someone can help me to improve my model mesh. Right now my model cannot run a simulation in fluent, someone told me to ask this forum, maybe there is something wrong on my model mesh, hope someone can help me, please (sorry for bad english) https://www.mediafire.com/?dg72rz80p19vnd6 this is my model ICEM file, hope you guy can look onto it |
May 23, 2014, 11:04 |
Sebastian Engel
Rep Power: 20 |
Hi MatJo,
your target is to simulate a piston engine, isn't it? The main cause of problems seems to be the geometry. There are a lot of junctions of geometric entities which do not match. See the following pictures. For example, the duct's fillet jumps from a big radius to a smaller one (first picture). Also check the source of your geometry/CAD data. the smaller ducts seem to be not proper attached to the main cylinder(2nd picture). Is that desired? junction.jpgjunction2.jpg The geometry the way it's now seems to need lots of work to be cleaned. Firstly, I would suggest you to simplify your geometry, not in ICEM but in a CAD program. ICEM has all the neccessary tools too, but i guess you might be faster using CAD. Only after you cleaned your geometry you can redo your mesh. To do so, please redo the tutorials of ICEM, especially the Hexa Mesh Tutorials for a 2D and 3D Pipe Junction. Also the sphere cube geometry tutorial can't hurt. There is one big flaw in your mesh right now. It's visible in the following picture. You always create an additional block to cover the junction of different duct cross sections. That way you will have very thin and distorted elements which self-intersect. You will have to eradicate all those blocks and patch through the topology of the block structure like it is done in the tutorials. Maybe start with blocking just one duct at a time. junction-vs-patch.jpg With regards, Sebastian Last edited by bluebase; May 29, 2014 at 10:25. |
May 28, 2014, 19:49 |
Rep Power: 12 |
Hi Sebastian,
thank you for you help and tips, i will try to follow your suggestion, i really appreciate your help, |
icem |
[ICEM] Bad Mesh Quality in Hexa | Axlex | ANSYS Meshing & Geometry | 2 | April 14, 2014 10:03 |
[ICEM] how to improve mesh quality in the hydrocyclone | veerukvb | ANSYS Meshing & Geometry | 2 | October 29, 2012 05:14 |
[ICEM] Low quality mesh | Memme | ANSYS Meshing & Geometry | 1 | May 25, 2012 02:02 |
Improve Mesh quality - airfoil simulation | Lukas84 | STAR-CCM+ | 4 | July 6, 2010 10:07 |
Quality of extruded mesh in ICEM CFD | Andrew | CFX | 1 | December 28, 2006 10:35 |
