May 28, 2014, 12:24 |
mesh combustor head
kai
Rep Power: 12 |
Dear friends, Would you mind to give me some tips on how to mesh this complicated combustor head? It has a central cone shape on which 10 holes are distributed uniformly. The holes are used for fuel injection, so it has to be meshed. If really needed, i'd like to share the .tin file with you, but it will be better if you could just give some tips. Thanks! |
May 29, 2014, 13:49 |
kai
Rep Power: 12 |
no answers?
May 30, 2014, 07:29 |
Javi
Hi Kai,
there is a tutorial exercise with a semisphere but inside it there is a cube. You can try to do it to get some ideas. Anyway, I think you need other approach to get this mesh because hole and little cone near to them. Maybe if you share your geom someone can help you in better way |
May 30, 2014, 08:45 |
kai
Rep Power: 12 |
thanks for your reply, i have meshed it successfully. Even though the mesh is with bad quality but its just time consuming to improve the quality.
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
