[ICEM] Project Faces Failed!
Old   July 26, 2014, 21:04
Default Project Faces Failed!
Syavash Asgari
syavash is on a distinguished road
Hi Friends,
When I try to generate a hexa mesh inside a 3-D cavity using "Project Faces" scheme, ICEM fails and the generated grid (inside) is twisted in vicinity of cavity wall. This twist propagates through the cavity and gradually fades away.
I have tried "Project Edges" scheme and I could get better outcome, but I need to know how to resolve this problem when using "Project Faces". I have attached two figures showing aforementioned schemes compared together.
I will appreciate any comments.
syavash is offline   Reply With Quote
Old   July 27, 2014, 16:21
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
it is simply association problem...
Far is offline   Reply With Quote
Old   July 27, 2014, 17:12
Syavash Asgari
Thanks for replying Far,
I have associated all the edges to their corresponding curves and I have also manually associated the cavity faces to their corresponding surfaces, but it does not solve the problem. I can upload the blocking if it would help to find where the problem lies.
Thanks again.
Old   July 27, 2014, 17:45
Far
Sijal
please upload .tin and .blk
Old   July 27, 2014, 18:12
Syavash Asgari
Uploaded.
Thank you.
Old   July 28, 2014, 10:39
kad
kad will become famous soon enoughkad will become famous soon enough
I think the problems are due to bad geometry/topology. There are several overlapping curves and the surfaces of wing and cavity are also overlapping each other.
You can trimm these surfaces and deleted one of them. Delete all curves and points permanently. Then rebuild topology by using Repair Geometry -> Build topology . Finally associations have to be corrected.
kad is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
