[GAMBIT] Curved Tube Using a Two Phase Approach
Old   August 20, 2014, 05:06
Default Curved Tube Using a Two Phase Approach
CR-7
Heat Pipe is on a distinguished road
Good Afternoon CFD Online
I'm trying to simulate the following geometry but I need some help about how to draw it correctly as the way of drawing 2D face and then Revolve or Sweep is using for the first time.
Then, when I mess some of 3D geometries I could not get the following as I'm using Hex/Wedge and Cooper
Heat Pipe is offline   Reply With Quote
Old   August 20, 2014, 06:20
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Create one section (disk)
Create one edge which will describe your center line
Then you can sweep your face (disk) with your edge, and you get your 3d volume.
Now if you want a full hexa mesh (no pave), you have to split your domain. By decomposinf it, you will get a nice hexa mesh.
In your case, the decomposition is O-grid type.
Typically you draw a square inside your disk, and you split your disk with the square. Check here for instance: http://www.cfd-online.com/Forums/ans...id-gambit.html
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 20, 2014, 10:58
CR-7
First of all ,
For drawing 3D Pipe O-rigid. I followed a new way to get that pipe
and my pipe is below, take a look and then give your evaluation
Old   August 20, 2014, 11:33
CR-7
And For my thread. I made a circle face and to connect the center line with that circle I did not get the method. with pictures if don't mind
Old   August 21, 2014, 01:13
-mAx-'s Avatar
Maxime Perelli
Originally Posted by Heat Pipe View Post
First of all ,
This is not an O-grid. Doing this you won't be able to mesh the inner pipe with hexa (but with pave you will)
As I said, you need to have a square inside your disk
http://www.cfd-online.com/Forums/ansys-meshing/124634-how-plot-s-pipe.html
Old   August 21, 2014, 04:10
CR-7
Okay MAX
if I considered my geometry as presented above as a concentric annuli is my procedure correct from drawing and meshing
To connect the arc with the Slice have faced a problem as below
I used Radius 20 mm for both the arc and the face
Old   August 21, 2014, 04:13
-mAx-'s Avatar
Maxime Perelli
is the yellow edge the path for sweeping?
if yes, then it cannot be coplanar to your disk
Old   August 21, 2014, 04:23
CR-7
Yes Max the yellow edge is the path of sweeping
I did point in the center of disc to be the center of that path got this
Old   August 21, 2014, 04:38
-mAx-'s Avatar
Maxime Perelli
your edge has to belong to (xz) plane
Old   August 21, 2014, 04:55
CR-7
Even with XZ failed
Old   August 21, 2014, 04:58
CR-7
Now the face in XY and the path in XZ
Old   August 21, 2014, 05:08
-mAx-'s Avatar
Maxime Perelli
align your edge with your disk so that 2 points are coincided
Then in sweep too select perpendicular type
Old   August 21, 2014, 05:23
CR-7
Let copy your dimensions in last two pictures
1- Radius of Disc is ( ? ) and xz plane right?
2- Selecting circular arc with the third method
Radius is ( ? )
Start angle ( ? )
end angle ( ? )
the center you selected the vortex of the disc or how
and also you selected xz plane
Sorry for my too much quires
Old   August 21, 2014, 05:31
-mAx-'s Avatar
Maxime Perelli
1- 15 in (xy) plane
2- just like yours , ie :
*radius 40
*start angle 0
*end angle 210
*(zx) plane
then you need to rotate your edge with 90° angle along (0 1 0)
Old   August 21, 2014, 05:53
CR-7
Now so-so
I got the geometry but what happened I didn't understand why?
Maybe my directions or orientations .
I followed all yr instructions
* Disk with 15
* Arc with 40 and 0-210 angles of start and end. The center was the disk vortex .
Than I did rotation to the path line and finally sweep with perpendicular type but I got this
Old   August 21, 2014, 06:31
-mAx-'s Avatar
Maxime Perelli
*create a plane with 500x500 (zx)
*split your tube with the plane, you will get 2 symetric domains.
Delete one and check if the geometry is ok
Old   August 21, 2014, 07:02
CR-7
I did your last point but as I told you something goes wrong !!!!!
Old   August 21, 2014, 07:23
-mAx-'s Avatar
Maxime Perelli
if you don't explain what the problem is, I cannot help you.
From your pictures everything seem to be ok
Old   August 21, 2014, 09:53
CR-7
Dear Max ..
My problem is before doing sweep, the disk and Arc-Path r connecting wrongly Not like yours. For that just take a look at the last picture after splitting the geometry by that plane
Old   August 21, 2014, 09:57
-mAx-'s Avatar
Maxime Perelli
It doesn't make any difference.
Interpret this edge as a vector.
Important, is the way to build your geometry: and you did it correctly
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
What is best mesh for cylinder tube? olivia FLUENT 7 January 16, 2014 05:55
How can I model nanofluids with single and 2 phase approach ? safikhani_hamed CFX 3 August 3, 2011 06:35
Statistical Approach for Lagrangian Two Phase Model Hesham El-Batsh Main CFD Forum 0 November 20, 1998 09:20
