O-grid ICEMCFD
Old   August 28, 2014, 08:46
Default O-grid ICEMCFD
kg1913 is on a distinguished road
Could someone tell me what is wrong with my O-grid? or how to fix it please?
kg1913 is offline   Reply With Quote
Old   August 28, 2014, 10:29
A. S.
apoorv is on a distinguished road
Hi, Check Associations for egdes and surfaces. I think blocking may not have been projected to surface.
apoorv is offline   Reply With Quote
Old   August 29, 2014, 03:47
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
either you have deleted block or face projection (which is done by default by ICEM) is not properly done. In case of later problem, do the manual face to surface association.
Far is offline   Reply With Quote
Old   August 29, 2014, 07:13
Thank you. If I do the face association, Ill get the following.. I don't think this is what you meant me to do right ? :S
Old   September 1, 2014, 03:15
Far
Sijal
share files
Old   September 1, 2014, 04:53
I have attached the file
Old   September 1, 2014, 05:53
Andrey
Ralen is on a distinguished road
The geometry file (*.tin) is needed. Not only the project file *.prj.
Ralen is offline   Reply With Quote
Old   September 1, 2014, 06:12
attached..
Old   September 1, 2014, 06:52
Andrey
Why the aluminium plate have null thickness (canal into the atmoshere have null length)? The results may be more reaslitic.
Old   September 1, 2014, 08:18
Initially I had a thickness. But I was advised not to have it. (thickness= 0.417499996721745).
Old   September 2, 2014, 00:42
Andrey
Something like that.
Old   September 2, 2014, 03:52
That looks great. Thank you very much could you tell me how you did this, please (step by step instruction if possible please)? I really would like to know how I can do this. (looking at it did, I guess you created another square cut blocking around the circle --> two o-grids?)
Old   September 2, 2014, 11:52
Default Changing geometry --> Error Out_NegVol.
  #13
I have decreased the step size, so the cantilever is closer to the top surface. For some reason, even with correct asccociation etc., it does not allow it to run in CFXpre. It gives me the following error. I had the exact same problem with another model. (Initial model will run in CFXpre, however after changing only slighly it gives me the error). I did check mesh as well.
| ERROR #002100012 has occurred in subroutine Out_NegVol. |
| Message: |
| A negative ELEMENT volume has been detected. This is a fatal |
| error and execution will be terminated. The location of the first |
| negative volume is reported below. |
| Volume : -0.2492E-12 |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver could not be started, or exited with return |
| code 255. No results file has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
Thank you.
Old   September 10, 2014, 05:14
Andrey
Create 3D Block.
1. Split block (prescribed point if possible)
2. Split block (prescribed point if possible)
3. Create O-Grid
4. Associate edges to curves (also I associate all inner vertices to appropriate points)
5. Move vertices
Old   September 10, 2014, 05:16
Andrey
6. Create O-Grid
7. Associate faces to surface OUTLET
My project is not ready for CFX. May require more associations (faces and edges).
Old   September 10, 2014, 05:56
Andrey
For flow around the plate cells are too big.
[ICEM] Double Y grid and single Y grid brissyben ANSYS Meshing & Geometry 5 July 27, 2009 09:24
Grid refinement. Sas Main CFD Forum 8 September 2, 2005 08:36
Grid Adaptation Suresh FLUENT 0 October 15, 2003 13:18
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 22:26
