[TurboGrid] GE rotor B geometry for Ansys turbogrid |
July 7, 2009, 18:18 |
Sunny
Guys
I'm trying to simulate flow in a compressor cascade(GE rotor B) using Ansys CFX. But I needed to get the meshing done with Ansys turbogrid 11. I got the GE rotor B blade profile data from a desertaion by Muthanna(1998) but turbogrid requires three data files: profile, hub and shroud. I created these other files on my own from the blade profile data and got a model data doesn't look right for turbogrid meshing. I need some help with getting a complete data file or an advice on how to create the right data files for my hub and shroud Sonny |
May 15, 2013, 00:20 |
Fluidic Heat
Rep Power: 14 |
Hub and shroud curves can be obtained by projecting the profile to meridional plane.
May 15, 2013, 22:36 |
Fluidic Heat
Rep Power: 14 |
I did not see the date.. Yes, what you said was right.. :-)
August 29, 2014, 13:54 |
how to create create the airfoil and hub data for TurboGrid
Abdulaziz Abutunis
Rep Power: 11 |
Please, I stuck with creating the blade and hub data files for turbogrid. I opened the files in the turbogrid tutorial on ICEM and saw that the data for the hub is a polynomial created some how to pass through the LE. and TE. of lowest airfoil of the blade. I am wondering if I can extract these data from solidworks or I should use bladegen to create them. I already have the data for the airfoil, but I do not know how to manipulate the hub coordinate to agree with the blade's and be valid for TurboGrid. Thanks Aziz |
August 29, 2014, 19:06 |
G. S.
Rep Power: 15 |
Dear colleague, what version of ansys are you using?
I can help you but right now I have version 12 Maybe if you send me a saved version that I can open, I can help you gerardosrez@gmail.com Best regards |
August 29, 2014, 20:01 |
Abdulaziz Abutunis
Rep Power: 11 |
Thanks for your reply gerardosrez,
The ansys I have in school is version 13 and 14. The airfoil is in fact a water turbine hydrofoil. The blade is untested and has a constant cross-section. I have drawn the all rotor on a solidworks, but I read in a thread that I should create the .curve files of the blade airfoil and hub curve in BladGen in order to import to TurboGrid . I have already imported the hydrofoil to BladeGen but I stuck with the hub. Thanks again for your help. |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 22:15 |
[Workbench] Meshing and export mesh from STL geometry | alerfreire | ANSYS Meshing & Geometry | 0 | March 26, 2013 09:25 |
[DesignModeler] problem with import geometry from catia | pavilion | ANSYS Meshing & Geometry | 1 | November 23, 2012 10:45 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
[ANSYS Meshing] TurboGrid export geometry after meshing | la7low | ANSYS Meshing & Geometry | 0 | January 13, 2011 19:50 |
