[ICEM] flow inside the solid mesh
Old   August 26, 2014, 01:42
Default flow inside the solid mesh
Mahdi
metmet is on a distinguished road
Hi guys
I have a 3D block in ICEM which contains fluid body and inside it I have smaller 3D part which is solid. after converting to unstructured mesh, in B.C section I select solid for solid volume and fluid for fluid volume. but when I run it in fluent while I want see the contour or vectors there is flow inside the solid part!! what should I do in this case? I know if I delete the solid part there wont be any flow because there wont be any mesh inside the part. but in my case I have heat transfer inside the solid so I need the mesh (I think).
I will be appreciated if you help me what should I do?
metmet is offline   Reply With Quote
Old   August 31, 2014, 08:47
Mahdi
"Hey Guys
I found the solution. In my case although I have created two different body "Fluid" and "Solid" but all blocks inside the domain were same. So I needed to convert the blocks of Solid part to different name. For this purpose I did right click on the Solid part in left hand side windows and selected "Add to part" from menu. The I clicked on " Blocking material, add block to part" and selected All blocks inside the Solid part which I wanted to be different block as Fluid body. And now I have two different block with two different body and every thing up to now is OK."
fluid body, solid body
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Immersed Solid Momentum Sources inside function Martinw CFX 1 October 10, 2013 17:14
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
