September 28, 2014, 19:40 |
ICEM 2D airfoil blocking
Molnár Bence
Rep Power: 11 |
Hello everyone,
I am new in ICEM CFD, but I have a really important project what I have to complete. So if anybody could help me, I would really appreciate it. I should do the same mesh to the a 2D airfoil like in this video at 1:56: https://www.youtube.com/watch?v=tYrb...FuzAcZf3IITffg I also attach a picture about this. I should use Quarter O-grid, C-grid, and H-grid as well, but I don't know how to do the blocking. If anyone could explain me, I would be really grateful! Thank you very much in advance! Regards, Bence |
October 7, 2014, 09:32 |
Gwenael H.
Rep Power: 20 |
Hello Molnár,
Well as explained in the video it's a quarter O-grid with an inner C-grid. You need be familiar with the merge vertices / collapse blocs (same as the PipeBlade tutorial -> "Step 3: Splitting and Collapsing Blocks around the Blade"). Basically you need to do the following steps: 1) Create initial surrounding block (see Picture 1) 2) Merge the vertices tool(under Blocking>Merge Vertices) and associate to the FF points (see Picture 2) 3) Create a Y-block (under Blocking>Edit Block>Convert Block Type) and associate to FF point (see Picture 3) 4) Split the Y-block twice on both sides of the FF (see Picture 4) 5) Create a C-grid selecting the blocks surrounding your airfoil (see Picture 5) |
October 7, 2014, 09:35 |
Gwenael H.
Rep Power: 20 |
6) Delete the 4 airfoil blocks or create a "solid" part with these blocks (see Picture 6)
7) Depending on the airfoil trailing edge type (sharp /truncated) collapse the two blocks for a sharp trailing edge. 8) Associate the vertices and edges, play with the position of the vertices and use the "edit edge" using a source and target edge for a better mesh quality (see Picture 7). Hope this helped. Have fun |
October 8, 2014, 03:24 |
Molnár Bence
Rep Power: 11 |
Dear Gwenael,
Thank you very much! It helped me a lot, now I am able to do it. Your answer will be a great help in the future who will search solution here for this problem. Thanks again! All the best, Bence |
airfoil, blocking, icem, meshing |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
[ICEM] Blocking strategy for a Multi Element Airfoil (ICEM) | mix | ANSYS Meshing & Geometry | 16 | January 17, 2016 13:41 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
