[DesignModeler] Modelling Pressure Vessel Problems
Old   November 12, 2014, 16:54
Default Modelling Pressure Vessel Problems
Victor Peter
victorpbr is on a distinguished road
I've started to model a simple pressure vessel model, consisting of only a cylindrical tube, and a hemispherical head. When I designed them in DesignModeler, they were both 1 single body, but I need to be able to control the mesh on the interface between the heads and the cylindric corpse, so I did some research and saw that the solution for my problem was having a multi-body part, so I sliced the body into 2 bodys, and grouped them into one single part.
Here comes, the problem, when I mesh the multi-body part, something weird happens, the cylindric corpse has quadrangular elements, and the spherical triangular. And if I do the same thing to the case of one single body the mesh is all triangular.
I run a simple analysis on both forms and the results were totally different.So I'm guessing that Ansys generated 2 different meshes.
In Short, I need to know how to make ANSYS generate a single mesh for my multi-body part.
I don't know if the policy of the forum allows, but I have a dropbox link of my analysis on both methods, to make it easier to see. If someone knows If I can attach the link here, please say and I'll edit the post.
Thanks a lot!
victorpbr is offline   Reply With Quote
body, mesh, multi, pressure, vessel
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 14:32
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
