[ICEM] Switching to ICEM from GAMBIT
Old   December 1, 2014, 07:41
Default Switching to ICEM from GAMBIT
Miro
miro2000 is on a distinguished road
Hello everyone,
I'm trying to switch to ICEM, from Gambit in which I have a lot of experience in. In contrast, I have just started using ICEM, so I have one strait-forward question in my opinion:
In Gambit, it was possible to create a structured 3D mesh in this way:
-> create 2D geometry (points -> lines -> faces)
-> create 2D mesh (edge mesh -> face mesh)
-> extrude 2D geometry (with mesh) to 3D
So in case you had structured mesh in 2D you get a nice structured 3D mesh. I would like to do the same in ICEM.
I have a geometry with lots volumes(in Gambit) and would like to avoid assigning blocks to every point/line/etc.
Is it possible to assign blocks in 2D and then extrude everything (like in Gambit)?
tl;dr: Is it possible to extrude 2D geometry together with 2D blocks, so no further assignment of blocks (in 3D) is necessary?
Thank you for reading and have a nice day,
- miro
miro2000 is offline   Reply With Quote
Old   December 2, 2014, 08:29
Miro
it seems to be possible. Anyway, I have another question:
Is it possible to add blocks to existing part without overwriting the blocks that are already in that part? For example:
I have 3 blocks and I want to create another: adding by surface overwrites existing 3 blocks and I only have one. Changing part name seems to have very little effect.
Thank you very much for your time.
Old   December 4, 2014, 16:09
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
I always split the blocks to "create" new blocks which i then could properly assign and delete the excess. i'm not sure if this applies to your case or not..
edoan is offline   Reply With Quote
Old   December 5, 2014, 04:32
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
hey miro..
this thread might be of some help to you..
http://www.cfd-online.com/Forums/cfx...-icem-cfd.html
i would like to add some information
if you want a 3D mesh try creating a 3D block from the start. It might look a bit complicated but you will get the hang of it pretty quickly..
Blocks cannot be extruded. only mesh can be extruded (as far as i know)
cheers
Ananthakrishnan is offline   Reply With Quote
[Commercial meshers] different results for meshes produced by gambit and ICEM zakir hussain OpenFOAM Meshing & Mesh Conversion 1 April 23, 2012 08:15
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
can we know y plus in icem or gambit? ravi CFX 1 June 18, 2007 23:56
ANSYS ICEM CFD Mesh to Gambit Simon Bergström FLUENT 0 January 19, 2007 11:53
switching from build 2 ICEM CFD 4.CFX bogesz CFX 4 February 27, 2004 01:31
