[ICEM] Meshing/blocking of complex structure
Old   January 13, 2015, 20:00
Default Meshing/blocking of complex structure
sorselina is on a distinguished road
Hi guys, I am very new to the world of CFD and I have some trouble with understanding about blocking and meshing.
I have done a fair bit of the tutorial, but the examples given in the tutorial about blocking/meshing (although helpful for my basic understanding), do not help me in achieving a quality mesh for my geometry since my geometry is more complex compared to the one in the tutorials.
My geometry is an impeller, which is enclosed by a cylinder. I want to mesh the volume between the impeller and the cylinder (the area where the fluid flows), and I was suggested to use the blocking method to get a nice premesh. The impeller without the enclosing cylinder (impeller.png) and the enclosed impeller (impellerdonut.png) can be seen on the attachment.
So far, what I have tried is blocking the entire area where the fluid will flow and deleting the blocks that are the impeller, as can be seen on blocked.jgp. Am I on the right way? Please guide me so that I can understand this better
sorselina is offline   Reply With Quote
Old   January 19, 2015, 14:05
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
it looks good... can you share your project ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 20, 2015, 08:27
Sebastian Engel
bluebase will become famous soon enough
The big blocks at the outer radius in blocked.jpg seem to be very distorted. A corner seems to be much bigger than 135 degree... but this appearance could be due to the low resolution of the screen shot. I think it could be a good idea to share your icem files.
bluebase is offline   Reply With Quote
[ICEM] Meshing of fluid and solid zone of complex structure through OCTREE Nils_H ANSYS Meshing & Geometry 8 February 21, 2020 16:34
Bottom and free surface level for complex bottom structure noid Fluent Multiphase 0 July 2, 2014 13:18
[GAMBIT] 3D Mesh for complex structure Shinobi ANSYS Meshing & Geometry 40 December 4, 2012 04:30
Meshing complex white-light/GOM based STL models jola Main CFD Forum 13 January 30, 2012 01:35
Gas flowing into a complex structure syens CFX 1 December 6, 2011 05:25
