[GAMBIT] Can't import .msh file made using gambit in Fluent
Old   February 3, 2015, 17:21
Unhappy Can't import .msh file made using gambit in Fluent
bhaibhai
bhaibhai is on a distinguished road
Whenever I load any .msh file in Fluent 6.3, it shows this error.
Reading "| utility fe2ram -tGAMBIT -d3 C:\Users\Name\abc.msh"...
GAMBIT file to RAMPANT file
Read 0 nodes, 0 elements, 0 groups.
Error in reading the file
Error: no nodes read from input.
Error: couldn't write output file.
Building...
grid,
Error: Null Domain Pointer
Error Object: ()
I actually made a surface of particular dimension using gambit. I meshed this surface so made. Saved the file and exported as .msh file.
Now, when I import the same file in fluent, it ends up showing the above error.
Kindly help!!!
bhaibhai is offline   Reply With Quote
Old   February 4, 2015, 01:27
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you can only import 3d mesh, or planar 2d mesh (xy>0 plane) in Fluent
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
fluent, gambit, mesh
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
