[ICEM] How to deleted hidden vertex
Old   February 8, 2015, 05:02
Default How to deleted hidden vertex
jexposito is on a distinguished road
I am doing a structured mesh by blocking the geometry. The problem is that I found some hidden vertex that they do not appear on the screen by default. They can be shown by doing display_nodes number 90 for example. Those vertex are bothering when I want to use a replay file because they are changing the name of the edge, there is any way to permanently delete them?
Thank you in advance.
jexposito is offline   Reply With Quote
ill defined primitive entry 'boundary' francisco.angel OpenFOAM Pre-Processing 16 September 8, 2022 06:11
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
