[ICEM] Issue creating geometry and trim surfaces
Old   February 8, 2015, 10:43
Default Issue creating geometry and trim surfaces
Maxim ma
M4x1m is on a distinguished road
Hello. I try to create a geometry with and eccentric rotating inner cylinder in an outer cylinder. My outer cylinder has a Radius R=65.2mm, inner cylinder a Radius R=65mm and the eccentricity e=0.1mm. First i create the geometry of my outer cylinder, than i extrude the inner cylinder and trim by curve and delete the inner surface.
My problem is, that after trimming the curve and delete the inner surface, icem also delete my remaining geometry which should stay 65.2mm-65mm-0.1=0.1mm.
If I make the hole smaler(inner cylinder) R=64.4mm I've no problems with the geometry but, for R>64.5 the same thing happens.
I've attached some screenshots.
Thank you for your help
M4x1m is offline   Reply With Quote
Old   February 9, 2015, 08:38
Sebastian Engel
bluebase will become famous soon enough
try to increase the geometry tolerances in the ICEM settings. Maybe, internally, the curves of the circles aren't well resolved, especially for such small scales.
With a fine resolution the trimming should work better.
bluebase is offline   Reply With Quote
