[ICEM] Replay Scripts: create curve from points
Old   February 16, 2015, 06:13
Default Replay Scripts: create curve from points
evan247 is on a distinguished road
Dear all,
I've been trying to use ICEM's scripting feature to automate mesh generation. My geometry (curve) comes from a .dat file of (x,y,z) coordinates of points, and I'd like to create my curves "from points". However, in the .rpl file I find the line to be sth like:
ic_curve point GEOM crv.00 {{0.00000000 0.30000000 0.00000000} {0.00492865 0.30000876 0.00000000} ....
, rather than saying "import from <filename.dat>".
My question is then: is it possible to use .rpl file to directly import points from another file, or I have to input the points (manually) every time?
Thanks!
evan247 is offline   Reply With Quote
Old   February 17, 2015, 13:10
Sebastian Engel
bluebase will become famous soon enough
Hello evan247,
the .rpl scripts use a language called tcl. That's why you can use that language's features.
To answer your question, no you don't have to input them all manually.
But.. you have to write a few extra lines in your replay script to load the data file.
I suggest you to read a short tutorial on tcl.
To give you a kick start, have a look at the following code snippet. I assume your data file uses a comma as separator.
# read file
set fp [open "filename.dat" r]
set file_data [read $fp]
close $fp
# define empty list
set xyzlist {}
# process data
set data [split $file_data "\n"]
     foreach line $data {
     lappend xyzlist [split $line ","]
# create line by point list
ic_curve point GEOM crv.00 $xyzlist
with regards,
Sebastian
bluebase is offline   Reply With Quote
Old   February 17, 2015, 13:50
Originally Posted by bluebase View Post
Hello evan247,
# read file
close $fp
# define empty list
set xyzlist {}
# process data
with regards,
Sebastian
Thanks Sebastina for the starting point - I will look into tcl language to get my script working!
Create geometry from mesh points in ICEM-CFD David Arthur Main CFD Forum 3 October 25, 2014 12:19
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
Create 2D hexa block from points alexey CFX 1 June 22, 2006 07:49
Normal to Line - Curve Equ. from Points A.S. Main CFD Forum 5 July 5, 2005 02:41
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
