[GAMBIT] one of the patches was not imported into Fluent
Like Tree2Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   February 14, 2015, 03:34
Default one of the patches was not imported into Fluent
afsaneh
afsaneh is on a distinguished road
hello
i designed a hydrocyclone in gambit with diameter of 165mm. i used unit for all of the volume except inlet part, with retain item. also, i used subtract for main cylinder and inlet cylinder, with retain item, and connect the below face of vortex finder. i defined 3 BC :inlet velocity and 2 pressure outlet. in meshing part i used quad/pave for inlet, outlet and the connected faces with 0.01 interval size and hex/cooper for all of the volumes with 0.02 interval size. but in fluent, one of my outlet ignored and i face with fatal error: invalid number. can anybody help me about what my mistake is, and is my procedure correct?
i really appreciate if you can help me
afsaneh is offline   Reply With Quote
Old   February 16, 2015, 01:30
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you should have a message in Gambit while exporting your mesh.
You can provide the dbs file and could take a look
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 17, 2015, 04:17
Default thanks
afsaneh
Dear -mAx-
thanks for your kindness, can i have your email address, to send you a pdf file that i built my geometry according that, and you help me if there is a wrong guide in it?
your sincerely
afsaneh
Old   February 17, 2015, 08:17
-mAx-'s Avatar
Maxime Perelli
your volumes are not connected
Connect all the faces (Geometry/Face/Connect Faces (All))
It will connect all your volumes, but you will loose one volume mesh.
Then remesh this volume
It should fix your problem
afsaneh likes this.
Old   February 17, 2015, 08:40
afsaneh
thank you for your guide
because recently i began to work with this software, i can't understand well some of the concepts, for connecting faces it means faces between volumes of all the faces even wall faces of the volumes?
if you can show me in this face i really appreciate you
regards
Old   February 17, 2015, 08:59
-mAx-'s Avatar
Maxime Perelli
left from the yellow select window, click and choose "ALL"
afsaneh likes this.
Old   February 18, 2015, 05:59
Default thanks
afsaneh
Dear -mAx-:
hello
thank you for your kindness and guide, it really helped me.
with best wishes for you
regards
afsaneh
How to start Fluent with Matlab?? Jay Hu FLUENT 8 November 9, 2022 06:30
Linux Fluent HPC parallel system check failed saad3000 FLUENT 1 January 8, 2021 03:34
[blockMesh] Merging edge patches Yosmcer OpenFOAM Meshing & Mesh Conversion 11 November 16, 2014 14:51
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 07:46
Regarding periodic BC in ICEM generated grid Tarak OpenFOAM 32 April 30, 2013 14:46
