[ICEM] surface mesh size, unstructured 3d mesh
Old   March 2, 2015, 13:35
Default surface mesh size, unstructured 3d mesh
space slug is on a distinguished road
hello,
I hope somebody could clarify, why tris sizes differ so much on the same part (see screenshot).
I am trying to generate 3D tetras, and this kind of mesh gets generated when I go straight to tetras (Mesh -> Compute Mesh -> Volume Mesh). If I only compute surface mesh (patch independent), this does not happen, though another problems appears.
The part mesh size max is set as 0.004 (I can set it as 0.002, it makes no difference), curvature refinement is on with 0.003 min size limit. The surface edges are 0.01 apart, the geometry has been built in ICEM.
Thank you.
File Type: jpg Screenshot from 2015-03-02 12:17:45.jpg (53.1 KB, 42 views)
space slug is offline   Reply With Quote
Old   March 2, 2015, 15:26
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
lower your max element size
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 2, 2015, 16:07
it does not work.
Sorry for not being clear: settings for max element size are only being respected on part of the surface, and my question is why it takes place?
I also found recently that it only happens when I generate tetras with hexa-core. Maybe that is the reason.
Thanks
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
