March 9, 2015, 16:09 |
Boolean operation failed
Aberdeenshire
Rep Power: 11 |
Hi everyone,
I'm in need of urgent help pls. I tried creating a boolean subtraction, i.e, to subtract the cylinder surface from the rectangular domain as in the picture below, but it didn't work. Could someone explain how I could do this. Thanks Boolean problem.jpg |
March 10, 2015, 03:30 |
Amin
Rep Power: 14 |
hey
do you set correct setup for boolean setting? what is target and tool bodies!? |
March 10, 2015, 10:54 |
Aberdeenshire
Rep Power: 11 |
Hiya,
Yes, I did. The target body is the rectangle's surface body, and the tool body the cylinder's. I think the problem is, because the cylinder rests on the rectangle it cannot subtract. Is there any other way I can perform flow over a cylinder with that setup without performing a boolean operation. Thanks for your kind help. |
March 10, 2015, 12:58 |
Amin
Rep Power: 14 |
maybe!
anyway, you can use "cut material" in cylinder part |
March 10, 2015, 13:07 |
Aberdeenshire
Rep Power: 11 |
Sorry, that didn't work either.
March 11, 2015, 00:11 |
Rep Power: 14 |
the problem cud be that both are sharing same surface!
Try to make separate part for each and then Boolean it. also can you check what error it is giving when you are trying to Boolean it? |
March 11, 2015, 03:03 |
Aberdeenshire
Rep Power: 11 |
Hi Kapi,
They are different parts. The warning message is: Operation would result to non-manifold bodies. Context: Geometry Engine; while generating Feature Boolean1 Thanks for your help. |
March 11, 2015, 04:46 |
Amin
Rep Power: 14 |
your sketch is simple! you can draw all of them in one part! without boolean or cut material! draw your rectangle and circle in one part and use "trim".
March 11, 2015, 05:11 |
#9 |
Aberdeenshire
Rep Power: 11 |
Hi Amin,
I don't understand. Is the use of trim not applicable to lines? Well, I tried it as suggested but it trimmed off the lines of the circle. I want to remove the circular surface from the rectangle, but it results to 0 thickness where the circle intersects with the rectangle. Hence the error message of non-manifold body. I am sure there is a way around this, which I don't know. Regards. |
March 11, 2015, 07:05 |
#10 |
Amin
Rep Power: 14 |
it isn't clear! if you want you can give me your model dimension and I will try to evaluate it...
March 11, 2015, 08:08 |
#11 |
Aberdeenshire
Rep Power: 11 |
Hi Amin,
Sorry, I'm new to modelling hence I don't understand much. I have attached the geometry below. Thanks for your help. Regards geometry.PNG |
March 11, 2015, 08:12 |
#12 | |
Amin
Rep Power: 14 |
now I'm in my office, when I came back to the home, I will find a free time and evaluate it... |
March 12, 2015, 01:45 |
#13 |
Amin
Rep Power: 14 |
well
the problem solved! there are different ways to design this sketch a simple way: draw main rectangle with these dimensions: 600*210 mm (20 mm below the x axis) draw the circle: R=20mm do a boolean draw a fake rectangle from tangent to the circle ( 10 mm below the x axis) subtract fake rectangle from main rectangle |
March 12, 2015, 17:26 |
#14 |
Aberdeenshire
Rep Power: 11 |
Hi Amin.z,
Thank you so much for your help. I truly appreciate it. Regards, Precious. |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
