[Workbench] Ansys Workbench nonlinear material model |
April 13, 2015, 22:07 |
Rep Power: 11 |
I am almost new to the world of FEM. So please forgive me for the question. I have the task to simulate a tensile test for plastic. Therefore I shall use various material models and compare these between each other. I already did a linear analysis with isotrope elastic properties. Now I want to implement a nonlinear material model (at the moment bilinear and multilinear, later Neo-Hooke, Mooney Rivlin). Meanwhile created in Ansys Workbench a bilinear as well es a multilinear material model by using experimental data. But the simulation does still act linear and doesnt show any plasticity. The results are almost the same as those of the linear calculation. And the strain of plasticity is zero. But I am definitely out of the linear area. In Ansys I chosed the nonlinear material. I considerd nonlinear effects, large deformation and auto time stepping with substeps. Does anybode know where my mistake is? Or what I am not considering? Would be really great, if you can help me. regards |
April 14, 2015, 15:16 |
Rep Power: 11 |
well I had an error in my bilinear model.
But nervertheless thank you |
May 11, 2015, 11:03 |
lazo
me to ..i have same problem..help..
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
Ansys workbench GDO model information is incompatible with incoming mesh | shuweixin | ANSYS | 0 | August 9, 2013 19:05 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
composit material in ansys workbench!!! | mehrdadeng | ANSYS | 0 | October 21, 2009 04:32 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 14:26 |
