[ICEM] Periodic Tet Mesh
Like Tree1Likes
  • 1 Post By RalfBecker
Old   April 16, 2015, 06:04
Default Periodic Tet Mesh
Ralf Becker
RalfBecker is on a distinguished road
I would like to mesh a rather simple geometry with a tetra mesh and two translation periodic boundaries. I have setup the periodicty with "GLOBAL MESH SETUP -> PERIODICITY". With the OCTREE Mesher it works like expected, while any other mesher (Advancing Front, Delaunay, TGrid) does not generate a periodic mesh. Checking the periodicity with "RIGHT BUTTON MESH -> Periodicty" I get the message "No periodicty defined".
Which steps are necessary to generate a periodic mesh with these meshing algorithms?
Thank you in advance
Ralf
RalfBecker is offline   Reply With Quote
Old   April 20, 2015, 09:35
Ralf Becker
ok, in the mean time I have found a solution which works in my case:
  1. define periodicity (global mesh setup)
  2. create patch dependent surface mesh on one of the surfaces with periodicity defined
  3. Mesh Repair -> Make Periodic -> Auto, select meshed surface
  4. Move Nodes -> Lock Nodes
  5. Surface Mesh Setup: "Respect Line Elements" & "Protect Line Elements"
  6. Patch dependent surface mesh on remaining surfaces
  7. Merge nodes -> Single Edges
  8. Create Volume Mesh
Hope this helps in future
Kind Regards,
Ralf
Far likes this.
Old   March 26, 2020, 16:57
Tim
timotie87 is on a distinguished road
I'm trying to do something similar, but when I try to Repair Mesh, Make Periodic, it only allows me to select single nodes, not the whole surface.
timotie87 is offline   Reply With Quote
Old   July 11, 2020, 07:14
Syavash Asgari
syavash is on a distinguished road
Same here, No "Auto" option!
syavash is offline   Reply With Quote
Old   July 11, 2020, 07:21
Syavash Asgari
Kind Regards,
Ralf
Hi Ralf,
I know it's a rather old post, but I cannot manage to find the "Make Periodic -> Auto, select meshed surface" option, nor the "Merge nodes -> Single Edges" one.
Would you mind to elucidate a little further?
Kind regards,
syavash
icem, periodicity, tetra
[ICEM] Low quality Tet prism mesh saisanthoshm88 ANSYS Meshing & Geometry 17 September 28, 2016 16:50
Contrast of hex mesh , tet mesh and polyhetral mesh Kiffer Main CFD Forum 1 December 4, 2012 08:51
[ICEM] hybrid mesh/Aligning tet with hex mesh shridharsn ANSYS Meshing & Geometry 0 October 17, 2012 11:29
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
