Ralf Becker
Rep Power: 15 ![]() |
I would like to mesh a rather simple geometry with a tetra mesh and two translation periodic boundaries. I have setup the periodicty with "GLOBAL MESH SETUP -> PERIODICITY". With the OCTREE Mesher it works like expected, while any other mesher (Advancing Front, Delaunay, TGrid) does not generate a periodic mesh. Checking the periodicity with "RIGHT BUTTON MESH -> Periodicty" I get the message "No periodicty defined".
Which steps are necessary to generate a periodic mesh with these meshing algorithms? Thank you in advance Ralf |
Ralf Becker
ok, in the mean time I have found a solution which works in my case:
Kind Regards, Ralf |
Tim
Rep Power: 10 ![]() |
I'm trying to do something similar, but when I try to Repair Mesh, Make Periodic, it only allows me to select single nodes, not the whole surface.
Syavash Asgari
Rep Power: 18 ![]() |
#5 | |
Syavash Asgari
Hi Ralf, I know it's a rather old post, but I cannot manage to find the "Make Periodic -> Auto, select meshed surface" option, nor the "Merge nodes -> Single Edges" one. Would you mind to elucidate a little further? Kind regards, syavash |
icem, periodicity, tetra |
[ICEM] Low quality Tet prism mesh | saisanthoshm88 | ANSYS Meshing & Geometry | 17 | September 28, 2016 16:50 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Contrast of hex mesh , tet mesh and polyhetral mesh | Kiffer | Main CFD Forum | 1 | December 4, 2012 08:51 |
[ICEM] hybrid mesh/Aligning tet with hex mesh | shridharsn | ANSYS Meshing & Geometry | 0 | October 17, 2012 11:29 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
