[ICEM] Very weird, pre-mesh does not generate volume mesh after setting nodes on some edge. |
April 30, 2015, 12:06 |
Dongyue Li
Rep Power: 17 |
Hello guys,
Im using ICEM to generate mesh for a stirred tank. Every thing is fine until setting the nodes number on some edge. Before I set the nodes number, we can see this mesh is totally fine and very good: But we can see some edge only have two nodes. So I set this edge's nodes number to be 5 or 7 or sth. Then it becomes like this!!!: What happend???????? Then if I cut plane, I found there is no volume mesh.... Premesh does not generate volume mesh after I setting the nodes number on some edge? So weird.... Any comments is welcomed. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
