May 9, 2015, 07:46 |
how can i set the number of mesh
renyyz
Rep Power: 11 |
sorry for the newbie question. i am still new in this software. i want to make a grid independent study to validate the experiment data with simulation data.
my question is, it possible or not if i want to mesh my model with specific number of mesh (element), instead of using a coarse, medium and fine function? for example, i want to mesh my model with 500,000 number of element of mesh. btw, im using ansys workbench 15.0 (fluent) |
May 9, 2015, 07:53 |
Number of elements can be controlled more in hexa meshing. In unstructured meshing it can be done but will need a lot of mesh settings for parts, surfaces, curves etc.. Either way it is hard to achieve a specific number of elements but you can mesh it to almost the number of elements you require.
It depends on the geometry too. For simple geometries the no. of . elements can be controlled easily |
May 9, 2015, 08:05 |
#3 | |
renyyz
Rep Power: 11 |
May 9, 2015, 08:57 |
May 9, 2015, 09:12 |
#5 | |
renyyz
Rep Power: 11 |
is there other way to do other that ICEM? i dont mind if i get the number of element quite far from what i am specific, as long as i can control it. better if i can do it in mesh fluent only. |
May 9, 2015, 09:21 |
#6 | |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
